Fuel sending unit adjustment
fixit101
'88 Procraft 1650v w/25 gal fiberglass tank ...sending unit has two wires on top. I was able to loosen two small screws on top and adjust the fuel gauge on the console to match what I had in the tank. is this a correct procedure to do for a sending unit?
Also the part that I adjusted looks like a fuel gauge itself and you can take it off the sending unit without having to remove the unit out of the tank. it fits into a bowl shaped pocket right on top of the sending unit. How does this thing work?
