MaxGlide
Thread starter- Joined
- Aug 20, 2020
- 194
I just want to know if I’m on the right track here.
My old fuel sending unit was showing erratic readings on the multimeter so I got a new one. Tested it on the multimeter and it was moving smoothly through the range of 30 to 240 ohms, or what would be empty to full. But when I hook it up to the fuel gauge, even when I manually move the arm all the way to full, it’s only showing 50% on the fuel gauge.
I double checked all of the grounds and even hooked one wire up directly from the sender to the ground terminal on the battery, and it’s still reading the same.
So my thinking is that the sender wire from the fuel sender to the gauge is somehow compromised and impeding the flow of the signal.
For my next test, I’m going to make sure the tank is completely full and see how the gauge reads. If it’s still not reading properly, I’m going to run a new sender test wire directly from the unit to the gauge.
Am I on the right track for sorting this out?
Thanks in advance.
Wayne.
Thanks in advance.
Wayne.
