Fuel Ratio 235hp Johnson 1985 V6.
stuee1
Hi,
I have a motor as listed in the title.
When i purchased the motor the vro was disconected and its was running mixed. I have been using 50:1 as someone said it would be that but im not too sure as im using a tc2 low smoke oil and it still smokes and along with the constant oil stains / dribbles down the leg.
Is this the correct ratio can someone confirm.
thanks
50:1 is correct.----If you run constant full throttle you might want to go 45:1 on it.-----If you trailer with motor tilted up and fuel in the carburetors you may get leakage.-----Running fuel out of carburetors is best to reduce that leakage.
