Fuel quick connect
Sea Rider
Re: Nissan 6b won't start
If have spark and sat for a while without bowl dry, probably have a stuck needle inside carb...
Happy Boating
pvanv
I have Nissan 6b and it won't get fire. Sat for a while. What to do? And do nissand take a special fuel quick connector?
Assuming your model is NSF6B, right? Did you test for spark? Is the stop lanyard clipped on? That motor has a very reliable ignition system, but it is possible that you have a gunky carb from sitting with fuel in the bowl. If you need the fuel line quick-connector, you would buy FUEL CONNECTOR - ENGINE/FEMALE (4-STROKE) Female fuel connector - Engine side 8mm (5/16"). This is the connector that is installed on the fuel hose that connects to the motor. Fits all 4-stroke models. Part# 394702500M $15.52, available from any dealer, including me.
