USS Neversail
Thread starter- Joined
- Jul 8, 2002
- 117
83 Evinrude 50 HP<br /><br />Here are the symptoms . . . all this happens on the water, by the way.
<br /><br />bulb goes soft after running<br />in line fuel filter from tank to engine goes empty<br />dies at idle (after a while)<br />dies in gear (low rpm)<br />runs rough<br /><br />It does go to 4900 RPM's and runs fairly well the rest of the time. A little rough at WOT, but not bad. <br /><br />What I have done - <br /><br />-rebuilt carbs<br />-replaced fuel hose (tank to engine)<br />-replaced tie wraps with metal clamps<br />-have added Sea Foam to last tank of gas (still have it in tank) - had 1/2 full tank I added it to, then later added more gas and oil<br />-cleaned gas tank and filter on pick up tube<br />-cleaned fuel pump filter<br />-re-adjusted linkage<br />-replaced throttle cable<br /><br />I am going to rebuild the fuel pump, but am wondering if I can just pull it apart and clean it, or are there parts that I need to replace. <br /><br />So, does it sound like the fuel pump and, if so, clean or rebuild?<br /><br />Thanks
, <br /><br />Jason
