Fuel pump?
Deckbo
Guys, I need help.. i own a suntracker party deck '21. (deck boat). It's got a 4.3 mercruiser. I've recently picked up some bad gas. I am in the process of removing all the bad gas and cleaning the carburator. I don't have a manual for the boat yet. Can anyone tell me the location of the fuel pump? It's not mounted on side of engine, so I assume its in the tank. But, the tank appears to be not accessible.(inside hull)
wire2
Re: Fuel pump?
You will probably have to lift the carpet to access a cover.
Re: Fuel pump?
Ayuh,... If it's original, it's on the forward starboard corner of the motor...
Deckbo
Re: Fuel pump?
I'm positive its not on forward starboard side of motor. The fuel filter is mounted there for sure, but no pump. I'm gonna check the fuse box for a fuel pump fuse. It's probably electric mounted in top of tank. Thanks guys. Any help is good help...
