Fuel pump rebuild
Darren44
It looks like my 70hp merc is a 1981. Is the 'fuel pump kit' that is sold here what I need to rebuild my fuel pump? I noticed when the motor is idling with the muffs, the fuel filter bowl at the engine is only about 1/3 full of fuel. Its white so I can tell how much fuel is in the bowl. Is that normal?
18-7804 Fuel Pump Kit
Price: $3.64
Compare at $4.29
Manufacturer: Sierra
Replaces OEM part #
MERCURY MARINE 23014A1
Laddies
Banned
Re: Fuel pump rebuild
The sierra pump kit that iboats sells is fine if yopu don't need the ck valve then you will have to go with a Mercury kit and it's fine if your filter is half full they air lock at the top in most cases
Darren44
Thank you very much. I guess the pump is working. Should I install a bulb? There is not one on my boat?
