Fuel Pump Rebuild Kit '01 Merc. 4 stroke 75 hp
Nit640
I own 2001 Mercury 75 hp 4 stroke engine with dual manual fuel pumps. The top fuel pump is leaking fuel from beneath the top cover. Possibly bad o-ring or diaphram. I need to know if a fuel pump rebuild kit exists for this engine or do you have to buy the parts individually? If it does exist, who sells it and how can I get my hands on it? Engine S/N OT340558. I have checked all the marine dealers here in town and no one has one.
Nit640
Re: Fuel Pump Rebuild Kit '01 Merc. 4 stroke 75 hp
GGoody I checked with Sierra and the kits they have available are for 2 stroke Engines. Do you know of anyone else who may manufacture the fuel pump kits for my 2001 4 stroke 75 hp Engine? <br />S/N ot340558
PierBridge
Yes.<br />The Mercury Marine site in the link above enter your S/N like I did and then select fuel pump and then it gives you a choice of the 3 or 4 cyllinder engines pick your's and it will bring you to a parts list of every part you may need plus an exploded view of the fuel pump, it lets you add to the shopping cart any item from the pump you want.<br />The link would not let me go right to the end so you will have to go through the proccess mercurymarine and select mercurypartsexpress and then your serial number ...welcome to iboats.
PierBridge
You will get something like this. <br />Plus an exploded view of the pump.<br /><br />MERCURY (4 STROKE NITRO TRACKER) <br />Serial Number: 0T340558 Model Number: 1F75412YN <br />FUEL PUMP (S/N-0T408999 & BELOW) <br /><br /><br />Ref<br /># Part Number Description Qty Price Add to<br />Cart <br />1 804249T 1 FUEL PUMP 2 $116.10 <br />2 10-809564 •» SCREW (M5 X 35 MM) 4 $1.50 <br />3 809565 •» GASKET 1 $2.40 <br />4 809561 1 •» DIAPHRAGM 1 $8.95 <br />5 10-804253 •» SCREW 2 $1.10 <br />6 21- 41888M •» CHECK VALVE 2 $10.75 <br />7 804250 •» DIAPHRAGM 1 $87.10 <br />8 17-804254 •» PIN 1 $5.85 <br />9 24-809562 •» SPRING 1 $2.85 <br />10 11- 82388M •» NUT 4 $4.95 <br />11 24-804252 •» SPRING 1 $8.30 <br />12 804251 •» PLUNGER 1 $24.05 <br />13 10-804256 BOLT (M6 X 30 MM) 4 $0.65 <br /> 14 25-804255 O RING 2 $9.70 <br />15 12- 84292M WASHER 2 $1.35 <br />16 804257 FUEL CHANGE LEVER 1 $20.50 <br />17 17-804259 PIN 2 $0.10 <br />18 804258 SHAFT 1 $8.90 <br />19 17-804113 DOWEL PIN 2 $1.70 <br />20 804260 FUEL PUMP BRACKET 1 $16.50 <br />21 10-804112 BOLT (M7 X 48 MM) 2 $0.60 <br />22 35-877565T 1 FUEL FILTER 1 $14.90 <br />23 877538 1 SLEEVE 1 $3.20 <br />24 54-816311T STA-STRAP 8 $0.15 <br />25 32-830757130 TUBING (36 IN.) 1 $35.75 <br />26 22-822769 CONNECTOR 1 $0.50 <br />27 NSS CAP 1 - NSS <br />28 32-830756109 TUBING (2 IN.) 1 $33.45 <br />29 22-818993 TEE 1 $1.70 <br />30 32-830756109 TUBING (4-3/4 IN.) 1 $33.45 <br />31 32-830757130 TUBING (13-1/2 IN.) 1 $35.75 <br />32 32-828547633 CONDUIT (13 IN.) 1 $18.85 <br />33 32-828547T CONDUIT (3-3/4 IN.) 1 $24.70 <br />34 32-828547T CONDUIT (1-1/4 IN.) 1 $24.70 <br />- 27-804345A02 POWERHEAD GASKET SET 1 $269.20
