pursuit2460
Thread starter- Joined
- Aug 24, 2004
- 193
I have a 93 johnson 225. Today I hooked up a tee with a pressure gauge. Primed the primer bulb pressure gauge went up to about 15 psi then started to drop is this normal. Next I start the engine and the fuel pressure fluxuates from 2-3 psi at 1000 rpms. The pressure drops to 2 psi then you feel the fuel pump pump and psi raises to 3 psi. I let the motor idle for 5 mintues and check the primer bulb and it got soft. Ive checked the posts but nothing like what im encountering. thanks
