Hello Rolmops<br />Tried to do as you said, found a leak in the filter or fuel pump. The leak is at a place with the word filter. I think this is also the fuel pump because the fuel comes from the tank to this, from there to the carb. As I used ether fuel and sprayed around the lines and it would stall as if flooding, but catch and start running ok again. I saw the leak while pumping the bulb. Is this a fuel pump that need to be replaced or just a gasket to be replaced and do you have any ideal where I get the same. Thanks again...Dave...
