I have a 96 CrownLine 5.7LX EFI Bravo One, Serial #795033. I believe there are 2 pumps on this a mechanical and an electric pump, the boat will idle fine and run at full throttle anything in between the engine dies I changed the throttle position sensor, map sensor, iac valve and the engine is still doing the same thing, I cleaned the check valve on top of the tank, and even changed the fuel line, when I pulled the fuel line off the mechanical hardly and fuel came out of the line, could the mechanical pump be bad, I did this twice and very little fuel came out of the line. any help would be great.
Thanks
Rod
Thanks
Rod
