Fuel pump mounting screw
Meltedgears
I have a 1995 112 spl evinrude I was wondering what the mounting screws threads are for the fuel pump? I am having to buy a new fuel pump because when I got the boat they had removed it and took the screws. Thanks in advance.
Honorary Supreme Mariner
That non mixing fuel pump was mounted with 10-24 screws.----You will need the gasket too.
Meltedgears
I'm also having a problem with running at WOT it will only run at around 3000 rpms. I was thinking about checking the timing on the motor but Joe reeves method is blank. So I was wondering if tI ming could be my problem and what joes method was? Thanks
Meltedgears
I have done a spark test and everyone would jump 7/16 and the compressions all read the same on all 4 cylinders. And it has 4 new champion spark plugs. The people I got the boat from said it just had its spring tune up so I didn't know if he messed with timing or not.
