Brian 26
Thread starter- Joined
- Aug 14, 2013
- 574
Boat and engine model in signature.
I noticed it was taking some extra cranking to get my motor to start, the next day I heard a buzzing noise from the engine bay. On investigation it appeared the high pressure pump was making the noise and it felt hot to the touch - red arrow in my pic (unfortunately I don't know what the normal temp is). I pulled it off and there is nothing in the internal screen. I recently ran the boat out of gas while running it on the garden hose downhill (not sure if that maters). My plan is to replace it but thought I should check with you guys first. Is this the best course of action? I'm a little nervous about just throwing expensive parts at the problem.
Also bonus question, what is the valve with the blue arrow? I thought this was a pressure release valve so I pressed it, but liquid free flowed out of it. Water separator drain????
