Fuel Pump issue????????????????
tlamos
I have a 1986 115 H.P. inline 6 Mercury Two summers ago I had a problem with my motor not taking gas from a stop to wot,it would die out if I was to play with the throttle when it past the dead spot it would run fine,I changed all hoses primer ball,and fuel connection,that did not work. Someone on the forum told me it was a bad fuel pump so I changed it and have not a problem until today it is doing same as it did before,my question is do you think the pump needs to be replaced again?The pump was changed summer before last
Thank You
dingbat
Re: Fuel Pump issue????????????????
Did you clean the carbs?
tlamos
yes I did from a Mercury dealer
