Fuel pump going bad?
buenanj
I've been chasing a problem with my '99 70hp evinrude where the motor will act starved for gas and die. This problem only arises when the motor has been run for awhile and then the boat sits for an hour or two. The problem then arises when the motor is run after sitting and this problem is limited to being out on the water (ie doesn't happen on the muffs).
The last time this problem occurred, I was able to keep the motor running by pumping the fuel bulb every 5 seconds or so. The bulb never deflated but would be a little soft and the motor would die. My guess is that the fuel pump needs to be rebuilt but I wanted to see what others think. It seems odd to me that this problem only happens when the motor sits after having been run.
So far in tackling this issue, I've replaced the gas lines, gas, bulb, water pump, fuel filter and thermostats.
Thanks!
Chris1956
Honorary Supreme Mariner
Does it happen only after she runs for a while and then sits? Maybe it is a form of vapor lock?
buenanj
Yes, it only happens after the boat is run and then it sits. On the first run, the motor is perfect! I tried opening the gas cap on the fuel tank without any results. Any idea on where to look for an "upstream" vapor lock?
