Fuel pump for 6hp Johnson
peedee
Can I get a diagram of a fuel pump for a 6hp Johnson motor, model #GR69M S/n #C3590. I need to<br />see what it looks like so I can put the one I have back together.
JB
Re: Fuel pump for 6hp Johnson
There is a diagram in most Repair Manuals for that engine, PeeDee.<br /><br />Try your library, or just buy one. If you intend to work on it you need one.<br /><br />Good luck. :)
tassie ben
or you can get a diagram from epc.brp.com which is a really usefull resource for all johnson evinrude motors..not all but most.
that said a manual is the ducks nuts. Just don't buy a clymer manual like i did, some of the diagrams don't show all the parts ??? what sort of manual is that..and $80 Aussie dollars too...hmmm
good luck
GA_Boater
You must be kidding! You are aren't you? An 11 year old topic with the last post made over 6 years ago which was the posters last post here. :doh:
Please start a new topic with your question so currently active members can help you. Look at the top of the page and read the Help Tip.
