fuel pump check valves
tony murray
hi does anyone know?
iv just replaced my fuel pump check vales on my1983 merc 70 3cyl.
but im not sure which way round they go?
is there an easy way to tell the manual seems pretty vague.
thanks
Chris1956
Honorary Supreme Mariner
Re: fuel pump check valves
Easy, they are one-way valves. The fuel comes into the pump from the fuel tank on one side. The one way valve needs to allow this. so base down for this one. The other valve allows fuel to exit the pump, so base up for this one. Test by blowing thru assembled pump. if air travels from fuel tank side to motor side, valves are correct.
