LaqueRatt
- Jun 27, 2022
- 447
Took the boat out again today, with the Fastwin. Started nice, ran strong, then started to falter. Stopped it, took off the cover. Air bubbles in the line again and fuel in bottom of pan. Pumped the bulb, gas dripping off bottom of pump. Snugged up the lines tried again. Same thing. Seemed like the gas was coming out around the front cover on pump so tightened that center screw a little bit. Ran a paper towel around the pump while squeezing bulb. No more leak. Started her up, same crap. Tried pumping the bulb and found she'd run well again for a minute or so. That indicates the fuel pump is bad doesn't it? Another odd thing was as I was coming back in, the bulb went flat and wouldn't pump any more. Removed gas cap on tank, still flat. Has anyone ever seen that happen?
