stoked not
- Jul 20, 2001
- 143
On my last trip out, my motor was running along fine and then it cut out and died. I soon discovered that if I pump the bulb it run fine even at full speed. When I stop pumping it stalls. After reading many postings. I replaced the hose with bulb, in-line fuel filter, and installed a diaphragm /fuel pump kit. Still having the same problem.<br />I did notice that their seem to be fuel leek king from the carb area. It drips down to the cable tilt tube area. The fuel seems to have a oil mixture. My motor is a 97 power head with a 87 lower unit Mercury 115 HP oil injected. S/N-oc189160. I'm not totally confident that I did the rebuilt fuel pump properly but I had no extra parts and fuel is going threw the diaphragm into the in-line filter. My fuel tank is built in 30 gall. and do not see any air vents.<br />Thanks Stoked
