fuel problem
14dar
I have a Johnson j25tel3ssb that converted to a 35hp bord cyl pit 35 hp jets in carbs I have strong spark have good gas flow to thecarbs but no gas to cyls I have gas coming out low idol jets on top of carbs. Carbs have been cleaned so any ideas way not geting any fuel to cyl thank you
F_R
Re: fuel problem
So, you had it torn down and re-bored----is that what you are saying? It certainly would be hard to guess what is wrong. If the pistons fit properly and it has compression, and the seals are ok, it should draw fuel/air from the carburetor.
I'm thinking of a motor I rebuilt and couldn't get fuel to the cylinders-----after MUCH agony and troubleshooting, I tore it back down. Guess what? I had forgotten to cut a hole in a home-made gasket. Now who could have guessed that?
Triangleboater
Re: fuel problem
Think we need a bit more info from you 14dar. I can't really make out what you are trying to say. To convert the late 70's 80s 25hps to 35s , they needed the intake opened and the carb from the 35, not just different jets. All the passages in the carb are a good bit different from my understanding. Does it draw air when it cranking? Can you choke it and it fire (put your hand over the carb while you are cranking it)? Shoot some premix in the carb throat and lets see if it cranks up.
What are the compression readings?
Does it have spark that will jump a gap?
How do you know it isn't getting gas to the cylinders? The spark plugs look wet?
Give us a little more info.
Re: fuel problem
This is a 3 cylinder motor !!!!--Loop charged.----3 carburetors.--Built from 1996 to 2001.
rolmops
Re: fuel problem
It sounds like the fuel cannot make it past the reed box. If so you either have counter pressure instead of vacuum or the reeds are not working.
14dar
Re: fuel problem
This a 2000 3 cyl only different is bore size jets
14dar
Re: fuel problem
Plugs are dry doing compression check tonite and no have not tried putting my hand over carns
rolmops
Re: fuel problem
Now I'm going to change reeds on all three. Pulled plugs two where damp top was dry
Not so fast now.
Sometimes a bolt/plug into the crank case ,for instance a hole where you can attach a fuel pump, is left open by accident. this will minimise vacuum pull from the carburetor and the engine will not start. check out the other/cheaper possibilities before spending money on reeds where they may not be the problem.
It may be as simple as the carbs not properly screwed on to the block
14dar
Re: fuel problem
Ok now I just don't know went over everything to my eyes nothing missing had my wife turn it over held my hand over all three carbs they all where sucking air shot gas down carbs wanted to start but didn't any more ideals could use a lot now plugs still look dry forgot that one
