mrbell83
Thread starter- Joined
- Oct 23, 2005
- 148
Hey guys, I am having a little problem with my 71 9.5. I took it out for a few runs and I have seemed to isolate the problem its having. First let me say that the motor starts on the first or second pull and usually doesn't need the choke. It idles and cruises fine. When I go to take off is goes fine until it starts plaining out then it seems to sputter and hesitate and after a few seconds (maybe 5-7) it will rev more and plain. I have noticed that the ball on the fuel hose isn't really firm and if I pump it up a few times then go to plain it will go and not hesitate at all. <br /><br />I was told its an air leak, a bad fuel pump, or a bad head gasket......... What do you guys think? <br /><br />P.S. It seems to use allot of gas, is this normal for this motor? used 1.5 gallons of gas in less than 2 hours of running and it was 50/50 cruise/idle. (also there are no internal leaks that I can see)
