Fuel pouring out of vacuum switch
jeff68981
1995 Johnson 150 ocean runner J150EXEOM Will not start noticed fuel pouring out of vacuum switch. Is this easy to change? DO you have to take alot of stuff off to get behind it to take off the clip and put the nut on the new one?
Rustywrench
I see they are making a kit to fit both style engines System Check & earlier models. Take out the four screws holding the fuel bracket to the engine block. That will allow you room to work at the back of the bracket. Not to bad.
