Fuel/Oil Mixture 1972 Mercury Outboard
BoatGirl
Can you please tell me the gas/oil ratio for a<br />1972, 65 HP, Mercury outboard motor?<br /><br />Thank you
JB
Re: Fuel/Oil Mixture 1972 Mercury Outboard
Be glad to, Boat girl.<br /><br />You want a 50:1 gas to oil ratio. The most common way to get this (or close enough) is to put 1 pint of TC-W3 outboard oil into a standard, 6 gallon tank and fill it with 6 gallons of unleaded regular gas. <br /><br />Avoid gas with alcohol in it.<br /><br />Good luck. :)
sharkcat
50.1 is right use TCW3 oil. Remember putting alcohol in can give you gas :D :D & a headache :rolleyes:
cherylp
do you know what could be wrong 72 merc 50hp the hooks that grab the bar that holds motor down in reverse. wont grab bar. is there an adjustment and where.
