Re: Fuel/oil Leak Need Help Asap Please!!!!!
not to over simplify,check every fuel line,thats an enormous amout of leak.if you have a portable tank ,disconnect when not in use,if you have a built in tank,its always a good idea to have a water seperator,you can put a shut off valve in the line at filter,where exactly do you see it leaking from,is it out of the prop,or up high under the cown,under the cowl would leave me to think its a leak up top in powerhead area,it is possible your floats are passing,perhaps your tank is not venting well and pressure relieves through the carbs ,or elsewhere,another possibility is the fuel pump diaphram is leaking,but usually yu have performance trouble with that,the simple fix is a valve
