fuel mixture
yooper jim
I have an older Evinrude 6 horse. The previous owner mixed his fuel at 80/1. The sticker on the motor itself says 100/1. I'm wondering which is really the best way to go. Was he just protecting the motor by running it this rich. Seams like fouled plugs would be common. Any thought would be appreciated.
BonairII
Re: fuel mixture
What year is your motor? 50:1 is most likely the correct mix. It's def NOT 80 or 100:1. Those ratios are way too light on oil.
yooper jim
Re: fuel mixture
Model # is E6RCUD with a serial of B1389302 not sure of year but double checked sticker by fuel hookup and has gas pump image with 100 and oil drop image with 1 .
HighTrim
Re: fuel mixture
It is an '87, definately 50:1
The 100:1 sticker should have been removed by now, was a mistake by OMC.
yooper jim
Re: fuel mixture
Actually no, The previous owner had always mixed 80/1. I bought the boat last summer and ran the last of his 5 gallons out. Now I'm starting fresh and was just confused by the sticker. Boat ran great all last summer. Thank you for the info it is much appreciated. I will take the sticker off tomorrow and run it 50/1 when i fuel it up tomorrow.
tx1961whaler
Re: fuel mixture
:eek: I'd bet that turned out to be quite an expensive mistake.
I think they had to replace a few power heads. Some motors seemed to get some internal rusting during long term storage at 100:1, so they went back on the 100:1 rating and changed the stickers to 50:1.
yooper jim
Re: fuel mixture
Oh, you mean expensive for the company, i thought you meant previous owner. I bet it did cost them some repair refunds.
1946Zephyr
Re: fuel mixture
Yes, it was a very expensive mistake. Unfortunately, back in the 60's, they even said the 3's were good to run on 50:1 as well as the bigger motors. The 100:1 motors were the bigger mistake though and yes a lot of powerheads were rebuilt at OMC's expense. I don't believe it was because of rust taking hold during storage either. It simply was because there was not enough oil in the mix and engine parts went to pot very prematurely. Usually the pistons would suffer the most damage, because they are the parts that need the oil the most, in a non-friction type motor.
A lot of the reasons why outboard manufacturers were trying to make leaner running motors through the years, is because of the tree hugging liberals who lobbied to get the oil burning engines out of the water ways. They hate guys like me, who prefere to run 1957 motors with 16:1 mix. They would sooner have me crucified, than let me launch my boat. Now, as you see it, the political pressure has gotten so bad, that a lot of places will only allow 4 stroke outboards.
