Fuel mixture setting procedure 1974 75hp Chrysler
speed29668
What is the correct method for setting the fuel mixture on a 1974 75hp Chrysler? Thanks in advance.
Terry H
Re: Fuel mixture setting procedure 1974 75hp Chrysler
Speed...you really need a manual...I have an extra Seloc Manual that covers that procedure and if you could come over today I would let you use it. I assume you are referring to the lo speed jets...after you set timing, replace plugs and get everything properly tuned, carefull set the lo jet screws at 1.5 turns out from bottom...You need a test tank to fine tune the idle( must be under load...in gear). You adjust one carb at a time until you get it idling as smooth as possible. Easy trick if you have done this...might take some time if it's the first...just a Thought :cool:
speed29668
Thanks Thought. I have a Clymer manual but it does a realy lousy job explaining the procedure.
