canada6hpfisherman1971
- Jun 1, 2006
- 6
i also meant to ask what the fuel mix is for my 1971 Evinrude 6hp fisherman. i think it is 25:1?? maybe 24:1??<br /><br />thanks<br />robarchibald@hotmail.com
like I said....Originally posted by OBJ:<br /> Try 50:1....that's the correct fuel mix.
Originally posted by SLOOPY:<br />I believe amsoil does do something like this. BTW I have yet to burn up an engineOriginally posted by Walker:<br /> If Sloopy will personally give me a "Replacement Guarantee," no, make that a $3000 bond, I will be more than happy to run Scamsoil 100:1 this summer in my 120. Hell, I ran my little sailmaster evinrude two hours without oil one time and it ran for many more hours after that until it fell in the lake....
You guys think too much about what could go wrong/bad. Try thinking on the positiveOriginally posted by Paul Moir:<br /> I would particularly avoid 100:1 on that engine as it doesn't have a full complement of roller bearings. Even 50:1 (the manufacturer's recommended mix) is sort of pushing it. It has nothing to do with how good the oil is, just that plain bearings need a good oil layer to function properly. <br />It isn't as bad as the 4hp as it does have roller bearings on the big end of the connecting rod, but the small rod end, middle and bottom main bearing are all babbitt. It also has proper crankcase seals at both ends.
