Fuel Mileage Question
spdracr39
I just moved into a 2001 Q7 with 5.0l Mercruiser. My boat has an 18 gallon tank which seems small. What kind of fuel usage should I expect just on average cruise.
mccownk
Re: Fuel Mileage Question
My 2006 Q6 has a 46 gallon tank. Are you sure on that fuel tank size? Other 5.0 owners can comment on the fuel econmy which for boats is in gallons per hour.
spdracr39
Not positive. I look down in the back and saw the tank. It has a plate on it that says 18 gallons. I have not filled it up yet as I just got it today. I thought that seems very small though. Maybe theres more than one under there but that doesn't seem right either. I suppose it could have said 48 gallons and I didn't see it clearly but we'll see. Thanks for the reply !!
mccownk
Yep, every 2007 Q7 I have seen on the internet shows a 48 gallon fuel capacity. Now if some 5.0 owners can give some feedback on fuel performance you'll be all set. My 4.3L V6 does great on fuel.
CO_FOX
My 2010 Taho 195 with a 2009 5.0 MPI used 8 gallons per hour at 3000 RPM/32 MPH on a recent trip on Lake Powell. I ran 67 miles each way non-stop. Started the trip with 48 gallons of gas and 4 adults.
spdracr39
Wow guess I shouldn't have complained about the 5 gph my old mercruiser 470 was getting :) After a little elbow grease on the tag it does say 48 Gal tank. Thanks for the replies !!
