I currently have a 1990 Sea Pro 180 CC that reportedly weighs 1550lbs. I bought the boat without an engine because it was cheap, in solid shape and I had been given a 1996 Evinrude 60 hp. I wanted the boat to fish primarilary in fresh water lakes where I do not have to travel far before I start trolling or bottom fishing. I realised that the boat was under powered( the max HP is 140), but wanted to try it out since it would put me on the water without spending any more money. The 60 HP motor pushes the boat up to 28 mph in calm waters, but even throttling back to about 22 mph it still burns almost 6 gallons per hour.
Since getting the boat together I picked up a 1975 Johnson 115 and with help from reading several post here got it running. It appears to be a really low hr motor that was left at a towing company for over a decade until they decided that they wanted the boat removed because it was in their way. I plan to put this motor on the boat, but have seen where this series of motors have been referred to as gas hogs. So I have three basic queations.
1) Besides a good link and sink with clean carbs is there anyway to improve
the efficiency of these motors?
2) If I throttle the 115 back and cruise at 25 to 30 mph do you think that
the fuel consumption will be simular to that of the 60 hp motor at the
same speed since the 115 will not working as hard?
3) What would you estimate the top speed will be with the 115 on the boat
instead of the 60hp?
Thanks for any opinions or advice, I would love to repower with a newer 90hp motor, but that will be a few years down the road.
