fuel lines johnson 60 hp
scotgoplen
i was going to run seafoam through my motor since its been sitting since last oct,i ran the carbs dry then,when i pumped up the bulb it wouldnt stay hard then i noticed fuel dripping out of the motor,do the fuel lines and the goofy plastic connectors come in a kit?im not sure if my lines split or one of the fittings broke,can these be changed without removing the vro pump and or carbs?any specila tools or tricks to do this? tks scott
OBJ
Re: fuel lines johnson 60 hp
Scot....where exactly is the fuel coming from...a hose connection, carbs, fittings? Fuel lines can be bought in lengths and the fittings can be purchased separately. Check all your fuel lines to see if they have become hard with fuel and time. Replace any that have. When they get hard they lose their grip on the connectors. Most lines can be changed without removal of equipment.
