Fuel Line
amishboy
Anyone know where I can get a replacement for the fuel line mounted on the side of my 1973 Mercury 650/65 hp 3 cyl. It is about 8" long and is mounted between 2 brass swivel fittings. Probably need new fittings as well, as they are crimped to the line. Line goes from the tank fuel line to the fuel pump?
Clemsontiger
Re: Fuel Line
Someone who owned my 650 had the same problem. They solved the problem simply and on a budget. Cut off the hose, grind off the clamps and use hose clamps to hold the new hose onto the original fittings. Big spenders, I guess.
amishboy
Re: Fuel Line
Yes and at that time it was out of stock. I got fuel injector hose and brass fittings from Napa for around $12.00. Thanks
