Fuel Line USCG Type for Under RIB Floor
Status
Not open for further replies.
Terrapin
I am moving my fuel tank to the bow locker on my Highfield Classic 290 Hypalon RIB. Is USCG Type B1-15 hose acceptable for the entire run from the bow gas tank to the engine, or is USCG Type A1-15 required under the floor from the bow gas tank to the water filter separator on the transom?
kd4pbs
B1 is only for spaces that aren't enclosed where as A1 is rated for enclosed spaces. Why not just get the hose that you can use anywhere on the boat?
Terrapin
OK thanks, I will go with the A1 since I don't know whether I would comply with fuel discharge section (b) (2) (ii) of 183.558.
Any experience with flexibility of the Trident Marine A1-15 Part Number 365-0560 ?
fluidboat
You are routing fuel from a bow locker tank → under the floor → transom water separator → engine. That “under the floor” section is considered a concealed / poorly ventilated space, even on a small RIB.
Status
