Fuel Leaking?
mmilla0502
Hey guys I noticed I had what I think is fuel leaking from these two spots in the pics. I was trying to troubleshoot fuel line problems and pumped gas alot without ever starting the motor. Did I just overflow the carbs and did I do any serious damage?2012-05-16 17.08.33.jpg2012-05-16 17.08.50.jpg
Chris1956
Re: Fuel Leaking?
The carbs should not overflow. The floats and inlet needles are designed to stop that. Pull the cowling amd pump the primer. If you see fuel leaking from the carbs, rebuild the carbs.
