Fuel leak through the exhaust? 1966 Johnson 2-stroke
1966-60HorseJohnson
I need some help. I have a 1966 2-stroke, 60-hp Johnson Super Sea Horse.
I put my boat in the water for the first time last night. It started up right away and idled fine aside from pumping out a lot of thick white smoke. There was also a noticeable sheen on the top of the water once I got it running (I assumed it was oil, but now think it's fuel). And then it took me a few tries to get it into gear from neutral - after shifting I had to quickly increase the throttle to keep it from stalling. It tended to pump out a lot of thick white smoke while in gear, and/or when I increased the throttle.
Today I find there is fuel leaking and it appears to be coming from the internal exhaust tube. After running some water thru the exhaust tube by-pass, it seems that fuel was sitting in the bottom of the exhaust tube, as the water flushed more out. So I know what the problem is but what's the source of the problem? Is it possible that I just pumped the bulb on fuel line too much and flooded it?
More context: I've recently changed the spark plugs, gearcase oil, sprayed fogging oil into the carb and into the cylinders behind the spark plugs.
I checked and checked and the only place I can find leaking fuel is after the internal exhaust tube. I am 100% positive that fuel is not leaking from anywhere above the exhaust tube, as observable externally (i.e., fuel pump, fuel lines to carb & crankcase, etc.).
I also have another problem: when idling, there is no water coming out of the exhaust outlet, but I'm assuming that is a separate issue, correct?
Any advice would be appreciated. I'm still new to the boating world, but I have acquired the parts manual and owner's manual and have been studying them quite a bit. I'd like to know this thing inside and out, but at this point with the fuel leak I'm still very much in the dark.
Thanks
1966-60HorseJohnson
Re: Fuel leak through the exhaust? 1966 Johnson 2-stroke
I should also add that last night, I had the motor running for a total of about an hour or so. most of that time it was idle but I did run it in forward gear for about 10-15 minutes before cutting it off for the night.
tx1961whaler
You are aware that probably 20% of the fuel in that era of 2 stroke outboard passes through the motor and out the exhaust unburned?
Daviet
It sounds like it might be running a little rich, not uncommon for those old engines to have to run rich and leave a sheen on the water. There should be water coming out of the exhaust port on the exhaust housing. There is a large rubber hose that runs from the exhaust housing to the outer housing, maybe it's broke. I would think that if you run it for an hour and it didn't overheat the pump is working.
1966-60HorseJohnson
@tx1961whaler: Nope, I was not aware of that! I am still new to this, only got the boat last August, and the first time doing maintenance. Though I'm not really surprised that they do leak some. However, it seemed like a lot was coming out when it was running. Also, there was quite a bit that had leaked out overnight out of the water intake by-pass plate (from the exhaust tube) and whatnot.
@Daviet: i actually had the outer exhaust housing off today and that rubber tube is fine. I too was thinking that it wouldn't have run for so long if the pump was broken altogether. I was guessing that maybe the water discharge is just coming out somewhere else, like the exhaust outlet on the underside of the upper gearcase assembly.
You've reminded me - when I had the exhaust tube by-pass plate off today and peered in to the tube, I could see the water intake tube, and I noticed that there was a very small hole (like a few millimeters) in the intake tube. Is there supposed to be any hole in that metal tube? There were no other signs of wear or damage to it. Just the one tiny hole, it was perfectly round as if it was supposed to be there. I don't know if that would be something that would affect the water intake past that point.
Thanks Cap'ns! I appreciate it.
Will
