fuel issue
fisheymikey
hi everyone,
I have a fuel issue and I feel like an idiot but cant seam to figure out
it seams when I don't connect the fuel line to the fuel filter the bulb primer get the gas there quickly
but when it connect its like it has trapped air and no matter how much I sqeese the bulb it does not get up there.
I have a clear inline fuel filter and see that it does not go.
is it a carb issue and its not allowing the fuel to go out...
or a fuel pump need new gaskets
im just very confused
and ideas??
thanks
gm280
Re: fuel issue
Okay am I understand you to say that if you bypass the clear inline fuel filter and go straight to the fuel pump the primer bulb will pump up and get firm, BUT if you install the inline fuel filter and then pump the primer bulb it won't get firm...? If so you have either an inline fuel stoppage or it is leakng and therefore the primer bulb will not pump up firm...
fisheymikey
Re: fuel issue
I tried both... it does not prime at all with or without..
but when I remove the line from fuel pumb the bulb primes up right away
very confusing
foodfisher
Re: fuel issue
The primer bulb fills the carb. bowls then firms up when full. After starting, the pump takes over. If you can't fill the bowl/s till full, you might have the filter in backwards, the bulb in backwards,. Just follow the arrows.
Frank Acampora
Re: fuel issue
You don't say what engine. however: Disconnect the fuel line from the carb OR the bottom carb and work the primer bulb. If fuel squirts out, then the pump is not clogged. Now, you may have stuck inlet needles in the carbs. remove and clean them.
If no fuel comes out, then the fuel pump is clogged. Remove the pump (assuming it is the old style two stage, not Mercury square pump) and check the button valves to see that they are not varnished shut. Check the screen in the black plastic cap to be certain it is not filled with debris.
fisheymikey
Re: fuel issue
I have force 125 1988.
I do have them on the right way all the bulb and filter
when you say remove the pump you mean the filter cap or all the way removing the gaskets an so on...
thanks
mike
roscoe
Re: fuel issue
thanks
mike
no, remove the pump cover, gaskets, diaphragm .....
jerryjerry05
Re: fuel issue
If you squeeze the ball? and it doesn't firm up.
Either the ball is bad or the fuel pump diaphram has a hole.
I've bought new squeezies(tempo) and they were bad right out of box.
Or the needle/seat isin't working,if it's this the gas should pour out of the carb.
fisheymikey
Re: fuel issue
im going to remove the fuel pump and inspect. but if the diaphragm had a hole the motor would not operate?
im going to cape cod hope ill be ready
Mike
