Another Tricky Day II
- Jul 19, 2011
- 4
This is my first post to the site. I hope someone can help. I have a 2003 200 HP Mercury EFI Saltwater outboard, new to me. Once started the motor often times dies while at idle or at low throttle. However, if I can get the motor going for a bit, the problem goes away. Shut the engine down for 15 minutes or more, the problem will arise again when started. Otherwise the motor seems to run fine. Idles fine (when it idles), runs well at WOT and everywhere in between. Rebuilt the lift pump in the spring, new onbaord fuel filter, new fuel hose and primer bulb (x2), and I operated with the gas cap off so I know its not a venting problem. If the motor starts to peter out, a quick squeeze of the primer bulb bring it back. Sounds to me like the lift pump but as I said, its been re-built. I guess the rebuild could have gone wrong. Any tother ideas?
