Fuel Injector?
mjp
Hi all,
If a Merc fourstroke EFI was having fuel injector issues, what would be the symptoms?
Also, what would be a good fuel injector cleaner to run through it?
Thanks,
Mike
Silvertip
Honorary Supreme Mariner
Re: Fuel Injector?
Rather than deal with "what if's", you are obviously experiencing an issue with engine so why not just tell us what it is. The solution may not have anything to do with an injector and we save lots of time in the process.
Faztbullet
Re: Fuel Injector?
A faulty injector can cause the following: misfires,surging,bogging,plug fouling, fuel in oil, low idle, loss of top rpm. Also the injectors on a outboard(2 & 4 stroke) have filters in them and no additives/snake oils made will breakdown debris to clean them, you will have to remove them and send off for cleaning. See linkbelow and ask for Tony or Linda..
http://www.brucatosvs.com/
