Fuel Injector Gas Dripping How Replace Fitch 2000 HP YR 2000
JET OWEY
Hi all really appreciate any help.. the season is slipping away....
There is a small drip at this injector. Do I replace or take off and clean up?
Evinrude57
I dont know of anyone that does FICHT injectors, you can replace it with either a used or old stock injector but just be aware whenever you replace an injector the ECU will need to be reprogrammed with the new injectors specifications.
All FICHT and ETEC injectors are serialized and need that individual injectors specifications also known as coefficients programmed into the ECU with the EvDiag 5 Diagnostic software or you risk running lean and blowing the engine.
daselbee
I am sorry, but I think you are SOL. That year, the coefficients were supplied on a floppy disk. Evinrude will not release the coefficients even if you give them the serial number, which I see you have. They do not want the liability, and they want the early Fichts to die.
One option you have is to find a donor engine with the original injectors AND the original EMM.
Hook up EMM to laptop, and make a permanent record of the coefficients that are programmed in, and the corresponding injector serial number.
Then take one of those injectors, install, and program your engine with the proper coefficients.
You must use Evdiags version 4.5 in order to be able to go to the injector coefficient field, and enter the number via a keyboard.
That is iffy, because you might get a bad used injector from the donor engine.
Whatever you do, make a record of the coefficients for all the injectors on your engine ASAP. You will have to get that from EvDiags.
This is a BAD situation, and Evinrude should step up and provide the coefficient info, if you assume all risk.
As an aside, call DFI Technologies. It shows that they rebuild this year's injectors. They might be able to rebuild any injector of your choice, and provide the proper coefficients for you to use.
Worth a shot. www.dfitechnologies.com
Faztbullet
Either the above or find a later model 3.0 assy and bolt it on. To bad ist not a 99 as have a blown whole powerhead....
JET OWEY
Thanks all for the feedback. Backing up a bit.. problem is a small fuel drip observed at the injector.. no engine performance issues. Does the equate to bad injector or is there something else easier, considering the difficulty in just changing out? If the original old one gets rebuilt does it need reprogramming? My software is ver 1.42b 2003 and older...will this be able to get the coefficients? Of course running the DOS a pain and using the UBE connector I believe requires tweaking. Have had trouble getting that software going, most likely because of the cable I bought. Florida Injector rebuilds them too per their web site. I'll make it a priority to get the coefficients and while doing that maybe I'll see info about the injector condition?
Thanks again all.
jet
