I have a 2001 70 HP Johnson and the fuel guage does not work it is below E. I 12V and a good ground. I am reading 9.4 V on the pink wire or from the sender. I thought it was a bad gauge and got a new one from Iboats and same problem.
Take the pink wire off of the fuel sender, turn on ignition and ground it out. If the gauge goes to the full mark there's nothing wrong with that side of the circuit. If it doesn't go to full work your way back to the gauge, wiring, connections and ect.
Please use the "SEARCH" feature to search for fuel gauge issues. This circuit is probably one of the most discussed, illustrated, trouble-shot and photographed in this forum. In fact there is even a "sticky" at the top of the forum explaining how to use the search feature and the instructions -- guess what -- use the Fuel Gauge Problem as an example.
If you are getting 9.4 V between the sending unit wire and ground (battery negative), you have the system wired backwards. The body of the sending unit is grounded to the tank (if the tank is metal) and therefore to the negative side of the battery.
If you have the sender wired through the negative side of the circuit then you have the wires switched at the gauge.
