fuel guage not reading
trukjn
Have a 93 skeeter with Yamaha digital guages. Both fuel tanks are full but the fuel guage is reading 1/4. Turning the switch changes from 1/4 to 1/2 but always goes back to a 1/4 tank. checked wiring connections on the tanks and they are all tight. any suggestions on what could be the problem.
superbenk
Re: fuel guage not reading
Corrosion or varnish build-up on the sender internals. You can check the resistance with an ohm meter. Can't remember the correct resistance readings off the top of my head.
Could also be a bad/saturated float on the sender.
