Fuel gauge not working
290magnum
I bought a used boat at the end of last season and quickly discovered that the fuel gauge us not working properly. It seems to be stuck around the 3/4 mark with the ignition on, and returns to E when ignition is off. To make matters worse, it appears to have been an issue with the previous owner as there is a remote gauge on top of the fuel sender which is the one that I'm describing, the one on the dash doesn't move at all. Any troubleshooting sequences are greatly appreciated. I do a volt meter but am mo engineer so need pretty detailed instruction. Thanks
20PRIVATEER
Re: Fuel gauge not working
turn the key on, with your test light or volt meter, check the wires going to the sending unit for power. if you are not getting power at the unit run new wires. if it still doesn't work after replacing wires, get a new sending unit.
Do a search using the words "Fuel Guage Problem". You will very likely find nearly 100 responses, most of them with a diagram of the system as well as troubleshooting tips.
290magnum
Thanks for the prompt reply. At the moment I have a wire going from the S lug on the sender to the S lug on the gauge, a second wire coming from the engine ground to the gauge ground, and a third wire coming from my ignition to the ignition on the gauge. I have an empty lug with a '-' on the top of the sender...should there be anything connected there?
Ys - the metal shell of the sender needs to be grounded as well. The wire running from the engine to the ground lug on the gauge is a waste of wire. Ground is ground wherever you find it. All of the gauges on the instrument panel have a ground. The gauge ground can be attached to any one of those.
