Fuel gauge not working on AL tank
CptCrunch
A year ago I completely rebuilt a 1968 33' Chris Craft Cavalier Futura FB. In-so-doing, I replaced the 75 USg steel fuel tanks with 103USg aluminum tanks complete with sending units. I rewired the entire boat including the dash, but the fuel gauges have yet to work properly.
When I first turned the key, they didn't respond at all. So, I added a ground wire to each tank's mounting brackets. Immediately, one gauge rose to 1/3 full and the other to 1/4 full. But this is where they have stayed.
Would mounting my grounding wire directly to the sending unit help? I don't see how considering the tank itself has got to be every bit as good a conductor as the 14ga wire I used. Thoughts?
Phantom_II
Re: Fuel gauge not working on AL tank
Are the tanks themselves properly grounded to the boats electrical system?
The tanks have to be grounded, and the sending unit has to be grounded to the tanks and the electrical system.
Silvertip
Honorary Supreme Mariner
Here is the circuit again. It is the "sender" that needs the electrical ground, not the tank. But since there are bolts that secure the sender to the tank, then the tank would be grounded as well. A separate bonding wire between the tank and or sender to the hull is also required but not for proper gauge operation.
CptCrunch
I wrote: "When I first turned the key, they didn't respond at all. So, I added a ground wire to each tank's mounting brackets. Immediately, one gauge rose to 1/3 full and the other to 1/4 full. But this is where they have stayed."
Oddly, yesterday I ran a second ground wire, 12ga from the main power board ground to each sender's mounting screw and that seemed to have worked. Well, ....the gauges moved slightly higher. I still have no clue if they are working, but I'm crossing my fingers.
The tanks are 24" X 22" X 44-48". The sending unit is on the top middle and the mount is welded to the bottom edge. So, I'm guessing it was the fact that I'd secured the ground 3' away from the sending unit was the problem.
Just seems strange to me that with all that aluminum would conduct less than a 12ga wire. And yes, the entire boat - including every metal thru-hull - is grounded. I also have a galvanic isolator (the black box on the helm picture).
On that note, is it true that I am supposed to attach the 12V ground with the green safety 110v ground to ground the boat? I've read differing opinions. One said they need to be separate. This didn't make sense to me; the battery charger and 1500w inverter are connected to both, as is the propane/110v fridge (the propane uses a 12v cold monitoring system). Yes? No?
I will tell you though, the fridge and the charger are always on and the marina is hot, yet our zincs are 18 months old and look practically brand new. Amen for properly installed good quality galvanic isolators.
The wiring in photo of the helm is 1/2 completed, but this is the essence of what I did. I've also included a photo of the aluminum tanks. Notice the location of the mounts to the sender.
