fuel gauge bad?
rroop32
With a full battery the gauge reads full, even when the tank is clearly not full. with a low battery (in my case) 7.1v the gauge read close to 1/4 tank. when battery is fully powered the tank reads full. Would this be a bad gauge?
Silvertip
Honorary Supreme Mariner
Re: fuel gauge bad?
7.1 volts is not a "low" battery -- it is a "dead" battery. There are over 100 posts on "Fuel Gauge Problems". Use the search feature using those terms. Test procedures and diagrams of the system are included. The Sticky at the top of this forum shows how to use the search feature and it even uses the fuel gauge as an example. And just so you know, NO -- the fuel gauge is almost never the problem. Wiring and the sender are the issue. Test it -- them fix what's broken.
