Fuel Filter/Water Seperator
Puddy905
Hi. Just wondering if I should install a fuel water seperator in my boat for my 1982 115? I'm looking at the Quicksilver model as it's a good size and the price is right. Just making sure it wouldn't impede too much fuel flow.
Bifflefan
Re: Fuel Filter/Water Seperator
wont impede flow at all. allways a good idea.
Chris1956
Honorary Supreme Mariner
Use 3/8" brass nipples and fuel line.
Puddy905
Thanks guys. Already ordered the new fuel line and I'll get a filter ordered up soon too.
sschefer
The Quicksilvers are 25 micron filters. I recently switched from Racor 10 micron filters to Quicksilver 25's. Even though the 10's are rated at the same GMP flow rate I don't think they actually do. Gut feeling mind you no fact to back it up.
I definitly don't have the cavitation (air bubbles) in the Merc that I had with the Racor. Racor now sells the 1" spin-on with a longer adapter tube that's suppose to cure that. Personally I think the filter is just too long.
In any case, the original filter under the cowl has to stay if you still have the oil injection on the motor otherwise you'll get dirt from the oil in the carbs. If you're pre-mixing your fuel then you can remove the inline filter after you put your new f/w sep filter on. The inline at the motor is only a 70 micron filter.
