GBOUJOUKOS
- May 1, 2004
- 4
I've got an aftermarket external fuel filter/water separator installed on a a 2000 Johnson 150HP Oceanrunner. Yesterday the check engine alarm/light came on when I tried to run over 2000RPM. (at idle speed, there was no alarm).
I know this is a fuel restriction issue, so I was going to start by replacing both the fuel filter/water separator as well as clean out the stock engine mounted nylon filter. My question is this....the current external filter is a Sierra filter rated at 28 microns. A mechanic recommended I replace that with a 10 micron fliter. Will doing this further restrict fuel flow? Am I better off just replacing it with the same filter that is already there?
Thanks in advance!
Thanks in advance!
