Re: Fuel Consumption
i timed my 90 hp 2 stroke 6 gallons in about 1 hour 45 minuites wot, at 30 mph you do the math 8.6?
Will you send me some of what you were smoking when you timed it and filled it up if I PM you my address?
6 gallons in 1 hour 45 minutes is 3.4 GPH at WOT
EPI is a company that designs engines and gearboxes. They have a webpage with elementary level explanations of the derivations of some basic power equtions:
http://www.epi-eng.com/piston_engine_technology/thermal_efficiency.htm
TE (Thermal Efficiency) of an internal combustion engine is .0226 x HP / GPH.
In your case that would be .0226 x 90 / 3.4 = .60, or 60%.
Here's a quote from the website above:
The value of this Thermal Efficiency relationship is that, by assuming a reasonable TE value (27% - 29%), you can estimate the amount of fuel required to produce a given amount of power.
Notice that 27% to 29% is "reasonable"? If you really have an engine that's running at 60% TE, you're about to make Bill Gates look like a beggar. Any auto, ship, or plane engine manufacturer in the world would gladly pay you BILLIONS of dollars for engine technology that could do that. My company spends millions of dollars each year trying to improve TE by just 1%. The 30% you're claiming over modern technology would literally be almost priceless.
BSFC (as discussed by Smokingcrater) = 5.92 x GPH / HP
In your case your BSFC is 5.92 x 3.4 / 90 = .22 pounds per hour per horsepower
As pointed out by Smokingcrater, an efficient auto engine will have a BSFC of .45-.55. A 2-stroke is worse and the BSFC will be higher.
Here's another quote from the page referenced above:
An excellent BSFC for a well-developed, 4-stroke naturally-aspirated, high-performance liquid-cooled engine at 100% power is in the neighborhood of 0.44 ? 0.45. Claims of gasoline engine BSFC values less than 0.42 at max power tend to be suspect.
If claims of less than .42 tend to be suspect, what do you think a claim of .22 is? Try "utterly ridiculous" maybe?
One more quote from the EPI webpage:
So if someone tells you that they have developed a 4-stroke piston engine which, at max power, makes 300 HP on 20 GPH of gasoline, you can quickly calculate a BSFC of 0.39 and a Thermal Efficiency of 34.4%. You should be highly suspicious of such a claim.
If we should be "highly suspicious" of a claim of .39 BSFC and a TE of 34.4%, I can't imagine what they would advise about your claim of .22 BSFC and a TE of 60%.
As has been pointed out by QC and Smokingcrater, what you are claiming is physically impossible. Pretty much the equivelant of me claiming that my 3/4 ton 4WD Suburban gets over 50 MPG while towing my 5000 lb boat uphill.
