fuel consumption question
Frank Acampora
Re: fuel consumption question
Diesel is more efficient because it operates at a higher BMEP--base mean effective pressure--. not because of open throttle. This shifts the curve up the graph, producing more torque and more hp at a given rpm. all other things being equal --displacement etc. Also I believe deisel fuel has more BTUs per weight than gasoline.
QC
Yes higher compression and higher BMEP are good and contribute to a diesel's excellent fuel efficiency. Also high BMEP is why diesels typically have higher peak torque values than Otto cycle engines. But diesel engines maintain close to the same Brake Specific Fuel Consumption (BSFC) over their entire operating range, all loads and speeds, because they do not employ a throttle . . .
Diesels also get better per gallon fuel efficiency due to diesel having 138,000 btu's per gallon and gasoline around 122,000, but the chart I posted above is for equivalent energy efficiency the only true measure. btu/hp . . .
mike176
QC was pretty close to the text books there guys. lines up with what they teach in tech school during drivability class. That would lead me to belive hes had some form of formal training in this are.
Silvertip
QC you missed the point of "over a years time" and you also ignore the "how used" part of the equation. A simple test of your theory would be to start up both engines on a test stand doing absolutely no work. There is no doubt at any engine RPM the smaller engine will burn less fuel. But make it do some work. Now the throttle setting required to accomplish that work becomes very important. When the small engine runs out of breath the big engine can be doing equivalent work while burning less fuel.
My point in this discussion and the charts prove it, is that depending on what your intended use of the boat will be, the fuel economy (or fuel used if you will) over the course of the year can quite possibly be better with the bigger engine. The point you miss is that the 4.3 throttle MUST be open more to make the equivalent horsepower as the 5.7 at a much less throttle setting (1000 rpm less to be exact) AT THE SAME PERFORMANCE LEVEL. You seem so convinced that open throttle is most efficient but you don't prove it. If that was true, all of us should be driving with our foot on the floor. Again -- if Time is your measure of efficiency -- that's true. If fuel consumption is your measure, then "more open throttle" is not efficent (but I can point out that depending on setup, there is very little difference between total fuel burned at cruise vs wide open throttle over a given distance). Let's look at the small engine again. At 20 MPH the engine burns 7.3 G/hr. So a 43 mile trip will consume about 14.5 gallons of fuel. Now lets make the same trip at WOT. At 43 MPH the engine burns over 20 G/hr but the trip takes just a tick under an hour. Again, if time is important, go WOT. If fuel economy is key, run at reduced throttle. Do the same for the big engine. Take careful note that at 25 MPH the big engine burns 8.9 G/hr. At WOT it burns 40. On the same 43 mile trip the big engine takes something under 18 gallons at 25 MPH plus it woud have gone another 7+ miles. It didn't achieve that economy with "more throttle". It achieved it with less. But in both cases we are not comparing apples to apples. We are comparing engine of two drastically different displacements on the same boat. Therefore, how that boat will be used will determine over time which engine provides the best "overall" economy.
I will use one more real world example. The current Corvette with a very high power V8 will get as high as 28 MPG in about a 3500# car (and I happen to know that's true). My brothers 3.8 V6 Buick Lucerne also gets 28 MPG and I know thats true. The average family sedan with a four cylinder engine from virtually any manufacturer will achieve 28 MPG under the same driving conditions. Which do you think has the more open throttle. Clue -- it ain't the Corvette. I will throw one more in for good measure. Back when the 55 MPH speed limits went into effect the over the road truckers (especially owner/operators) had to make major gear ratio changes on their trucks or else trade them for models that had gearing more appropriate for the lower speed limits. Again, why do you suppose that was? Too much throttle and too much shifting because the engines could not run in the power band with the old gearing. Are you old enough to remember when some cars had "economy gauges" in them. If so, you will then recognize them as a simple vacuum gauge. Red was bad (low/no vacuum), and green was good (high vacuum). Guess which throttle setting provided the best economy. Hint - it wasn't more open throttle settings.
This is one of those discussions headed no where so I'm outa here.
QC
Why do I even try . . . ? I'll answer again, because Silvertip is giving this board incorrect info. First the truckers he describes did in fact re-gear their trucks for efficiency and performance. But they did not do it for throttle position because DIESELS DO NOT HAVE A THROTTLE.
Then there is this brilliant observation: "You seem so convinced that open throttle is most efficient but you don't prove it. If that was true, all of us should be driving with our foot on the floor." To which I ask: Why in hell would you do that? If the engine in your car is capable of 280 bhp and yet it only needs 61 bhp to cruise at 72 MPH (I made that up), why in the flyin' flip would you "command" 280? Which is precisely what your foot on the floor would be, a command for full power.
Believe it or not Sr. Silvertongue, you have once again come close to proving my point. Imagine that you have two engines in your car, one that was designed to make 61 bhp and another one that was designed to make 219 for reserve power. When we cruise at 72 MPH above we could just shut off the 219 bhp engine because we don't need it. But the little 61 bhp engine would in fact be operating at WOT.
Now, to be fair, if you did this on purpose, you would set the engine up to run at say 3200 RPM and also optimise the cam etc for exactly that RPM and you would then run it at WOT (at least very close), and what you would get is dramatically improved MPG. So in this case, yes, I would run that car with my foot on the floor for the little cruise engine. But when I wanted to pull a grade, I would flip a little switch to start my 219 bhp engine and I would get my 280 bhp available back under my control. And if anybody is paying attention, what I sorta described is cylinder cutout strategy that basically turns a V8 in to a V6 and then a V4 so that you have basically 3 or more little engines that you can combine together so you can run at a wider throttle setting for the horsepower required to get the job done. Instead of a much more closed throttle, that makes the air pump that your engine is work harder to deliver smaller amounts of power . . . ;)
The winky guy is getting really tired, so, since I have been challenged for proof by our Sr. Engineer, the following is provided for your perusal. Oh and before I do that, again for clarity, we are talking about ENGINE efficiency in these more focused discussions and the good doctor keeps throwing in hull efficiency to muddy up the discussion, and the only point I have been trying to make from the beginning is that if you have two boats identically set up, and you are looking for the best fuel efficiency at an efficient hull speed, the smaller of the two engines that can get the job done will provide better MPG due to a wider open throttle for the amount of work being done (work being the cruise). This is contrary to the commonly held belief that the larger engine will be "loafing" so it will get better economy, but it is the truth in a controlled environement within reasonable restrictions like a 4.3 compared to a 5.7, or a 5.7 compared to a 8.1. Or a 3.0 compared to a 4.3. Not a 4 stroke weed-whacker engine running at 27,000 RPM vs. a 7.4 MPI at 2500 RPM in a 3500 lb boat . . . And BTW, I never recommended that anyone buy a small engine in their boat. If you are gonna tow stuff and you want to go fast, find a 2000 model year 454 MPI 385 bhp. That's what I want!
This is from a Toyota site explaining the benefits of Hybrids (guess what, it is throttling losses often called pumping losses) :
Pumping Loss
The major cause of loss of efficiency at low power is "pumping loss". How is an Otto cycle engine designed for a peak power of 108 hp persuaded to run at an output of, say, 10 hp? The answer is that the flow of air into the cylinders is restricted by closing a "throttle" valve. This forces the engine to drag the air through a narrow opening, creating a partial vacuum in the inlet manifold. As the air entering the cylinder during the intake stroke is below atmospheric pressure, there is less of it. A smaller amount of fuel is injected and the resulting smaller fuel/air "charge" causes the engine to run at low power, as desired. But, as well as having this intended effect, maintaining the partial vacuum in the inlet manifold wastes energy. As the piston moves down during the intake stroke, normal pressure below it and a partial vacuum above cause drag on the crankshaft's rotation. This does also reduce power output, as desired, but at the expense of wasted fuel, which is an undesired side affect. Note that cars suffer from pumping losses even at highway speeds. The throttle is really only opened right up when accelerating or climbing hills.
Interestingly, diesel engines do not have this problem because there is no throttle. Low power is achieved by simple injecting less fuel. This is one of the reasons why diesel engines achieve higher efficiency. This technique cannot easily be used by petrol engines because the burn temperature becomes too high and damages the cylinder.
This is from a site describing a new Peugeot/BMW engine:
In a conventional engine the engine power output is controlled by means of a throttle butterfly. The required amount of air to be drawn into the engine is regulated by the position of the throttle butterfly; however, at certain engine speeds and throttle butterfly positions, the incoming air has to squeeze past the partially closed or closed butterfly, reducing the air flow into the engine.
Overcoming this resistance reduces potential power and overall engine efficiency and also increases fuel consumption.
tommays
I just have fun on my boat and go buy the fuel flow meter o:)
Tommays
Silvertip
Grin d:) I lied. And since we have now resorted to the smarty pants stuff I felt compelled. Map's asked a simple question about fuel economy and as usual the train was run off the rails. Here's what Maps asked:
What is the average GPH (not MPG) consumption at cruise speed for a +-3000lbs 18-19' bowrider with V6 4.3L MPI 220HP ?
And would a V8 5.0L MPI 270hp run about the same ?
To which my response was, and can be summed up in two words: "IT DEPENDS". In the discussions that followed I doubt I at any time used the term "always" so lets keep that in mind.
I in no way dispute the fact the 4.3 will provide better fuel economy than the 5.7 "IF" the boat is operated under identical conditions over any given period of time AND up to the limits of each engines HP. If I gave this board that impression I apologize - that was not my intent. That said, many boat buyers, especially first timers, tend to underpower their rigs which brings available power into the mix. Underpowering creates the situation which is the point I've been trying to make regarding fuel economy. If one expects to cruise with the 4.3 at 40 MPH with a boat load of people, the 5.7 would very likely show better fuel flow rates at that speed because the 4.3 must use more of its available power than the 5.7. Hence, by comparison, the 5.7 is loafing. The flip side of that is that because the 5.7 has more "available" power, there is a tendency to use that power which obviously uses more fuel than the 4.3 at WOT so you certainly can negate any savings and you must also dismiss any differences in speed. So you see -- my answer was simply "It Depends". Take the 40 MPH factor out of the equation and what you say is true. But in that case you get what you get with either engine. Best cruise economy may be 25 MPH with the 4.3 and 35 with the 5.7. But then Map says - geez, this thing cruises nice at 25 but when I try to cruise at 40 it sucks gas like crazy. Which brings us to the most important sentence in your last post was "I'm talking about engine efficiency". Glad you finally brought that up. While a small engine may be operating at maximum efficiency -- that small engine may not capable of the performance level the owner requires.
Now to your smarty pants stuff. You said: I'll answer again, because Silvertip is giving this board incorrect info. First the truckers he describes did in fact re-gear their trucks for efficiency and performance. But they did not do it for throttle position because DIESELS DO NOT HAVE A THROTTLE.
And to which you, QC are also quilty. While they don't have a butterfly in the intake that pedal thingy on the floor is a fuel management device (be it mechanical or fly-by-wire). The farther that thingy went to the floor the more fuel the engine consumed. Let's call a spade a spade and stop picking nits.
I have a fuel flow monitor on my boat so I know the effects of trottle opening on "fuel economy" within the limits of my engine. Your discussion of the cylinder deactivation or displacement on demand technology is nothing new as Cadillac used it back in the last gas crunch and failed because the controls weren't avaiable so the reliability and effectiveness of the system was less than satisfactory. Fact is, that technology could be used to advantage in boats as well. But it's not, and we are stuck without a transmission or a very wide selection of variable pitch props so everything related to power delivery and performance in a boat is a crap shoot. In the end, speed, fuel economy, flow rate, MPG or any other measure of performance will depend on how much power is available and how heavy handed the driver is.
Now I'm done and although I do stand on my fuel economy principles, I apologize to Map for helping to cause this train wreck. QC -- never underestimate someones knowledge about a topic - especially when its being approached from two different perspectives.
QC
Sivertip,
My diesel comment was only to accentuate the role a throttle plays in this discussion. Not really to make fun of you . . .
I too am done, and did not and do not intend to "win" this argument. The only thing that I was trying to get through to you was that Otto cycle engines are most efficient at wide open throttle. Which you continue to claim is false. That is the one and only reason I keep it up, because again, it is factual. And no amount of practical info or otherwise can change that.
You sir should never underestimate what being in the engine biz for 30 years makes one an expert on. This fuel economy efficiency thing is what I do for a living . . .
Maps
Ok I get it...euh I think so....no wait , I honestly get it !
2 same build boats ;
one with big engine and one with small engine. 6 happy people with beer aboard each boat CRUISING at same speed (25 or 30MPH)
After 1hr ride captain in small engine boat says to captain in big engine boat * jeez I CONSUMED more FUEL for the ride than you have *
captain in big engine boat replied * I may be saving money now but is it worth the extra 2k I paid for my big engine ? *
This tread is VERY constructive , more than I ever imagined...
just kidding THX guys ! d:)
