laddiemac1
- May 16, 2013
- 12
can someone tell me the fuel tank capacity of a key largo 176?
That's funny..... Four Winns may be including fuel capacity in the fuel fill hose too, so you don't have a leg to stand on in court..There should be an inspection plate, in the deck, directly over the fuel gauge sending unit. The tank will have a tag on it in that location. It'll tell you manufacturer, date of manufacture and capacity.
(Four Winns says my boat holds 110 gallons. The tank manufacturer says it's 109. I think I have grounds for a false advertising lawsuit...)
My .02
found label near fuel tank hoses.....its 35 gal....now i hve to figure out why the gauge was at e and it only took 15.4 gallons of fuel and the gauge was near full.....any ideas? one time the return line had gas in it and it wouldnt take very much gas...maybe a new fuel sending unit would be in order......wonder where i could get one......
There's something wrong with your vent system. There should not be any gas in it. The vent should be located at a higher point on the hull than the filler, and there should not be any dips ( low points) in the line between the tank and the vent fitting. The line can loop UP but not down.
