GobbleAndGrunt78
Thread starter- Joined
- Sep 28, 2011
- 7
I recently bought a used Tracker Pro 17 with a '98 Tracker Force (by mercury) 40HP. I've been chasing my tail trying to figure out why it misfires right at or above 4,000 RPMS. 127PSI on both cylinders. I've performed a Sync & Link, set cranking timing, replaced adapter plate gaskets due to exhaust leak under cowl, w/p impeller, foot oil, battery, propeller, starter solenoid, throttle & shift cables, both CDM modules with wires, spark plugs, reed petals/gaskets, fuel pump diaphrams/gaskets, all fuel lines, primer bulb, fuel filter, priming system hoses from carb to primer solenoid, recirculation/drain hoses from transfer covers to fuel pump, removed transfer covers and cleaned/verified flow through passages & elbows, removed recirculation/drain check valves & cleaned/verified flow through them. The prime solenoid seems to function correctly and will bog motor if key is pushed in while cruising. I've made sure my tank vent was open, and even ran it on a brand new portable tank with fresh gas & 50:1 mix of Mercury Premium Plus Synthetic Blend with Shell 87 octane. I've ran Mercury Quickleen through the tank a few times already. I peformed a decarbonization with Mercury Power Tune and cleaned the spark plugs afterwards. I removed the carb and disassembled, it was beautiful inside....no varnish/gunk at all, float looked to be set correctly, jets & passages blew cleaner through them easily. I peeked under the bottom of the flywheel to see if the stator had any melted gunk coming out or any cracked/broken magnets...none. I looked at the voltage regulator box to see if it had any melting or cracking...none. The motor has a definite erratic misfire at 4000+ RPMS, I can get it up to almost 5,000 but misfire is still felt. The previous owner had installed a tell-tale and the last time out I folded the hose over and zip-tied it shut to see if loss of water pressure had been causing a hot condition...no difference. The only odd thing I noticed a few weeks ago was I saw the volt meter go up to like 16 or 18V after startup, but within 30 seconds it dropped to 14V which is where it always runs....not sure if gauge was acting up, if this is normal, or if the regulator is messing up. I understand a bad regulator can fry a stator. I've HEARD the "black stators" mess up frequently and the "red stators" are tough. Looking at mine from under the flywheel, it appears black, not sure about the top side of it. I was an auto mechanic for 13+ years, but left the field in March, so I'm pretty good mechanically, but I'm getting a rough crash course in 2-stroke 101 right now! I work for Tracker Boats in the parts dept. Our techs are great guys, but aren't exactly seasoned pro's and are as stumped as me (if not worse). We are a Mercury dealer, so I have access to parts diagrams & service manuals. Any help/input is appreciated.
