Re: Frozen steering
Remove the bolt that attaches the link to the engine and determine which is frozen, the rod or the engine. All you can do is to start tapping the end of the rod with a hammer and be liberal with the PBlaster or other penetrant. Eventually the rod will start moving. Once you get her moving, keep working it and spraying it until you can get it all the way out of the tube. (You may not have room to get it all the way out- some boats require engine removal to gain the clearance to get the rod out.) But you'll be able to get to the rod and the inside of the tube. Both will be nasty. If the steering system is toast replace it. The tilt tube will need to be cleaned out with a round wire brush and more spray. Do it until it is clean. Then lube the inside and reinstall/replace the cable.
